question about supra injectors
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
couldn't find answer searching so figured i would ask. are the mk3 turbo supra injectors low imp.? if not has anyone tried using a resistor or etc. to make them work for the ca?
ThanksWei
fanta
hannibal
Car: Red Line to Glenmont
heres another guide...http://www.nissaninfiniticlub....72765
PS I got some info from the site fanta linked to. Are you sure the mkiii turbo injectors are top feed??
DSMs_Suck
Car: Money, *****es, and 40s
You CA guys confuse the **** out of me...I posted before that I didnt think your injectors were low impedence stock, but the response I got was that you have low imp. injectors stock (mind you most nissans have high):http://www.nissaninfiniticlub....34280
I will say it here... like I did there, the injectors are in a 7mgte are the same injectors in a 4g63 turbo, which guys upgrade out of all the time. You can usually find a full set of 4g63 turbo (make sure to get the 5-speed ones) for like $50-70
MurrayBTW... so you do have hi imp. injectors stock... correct?
