question about stock versus 9:1 ratios on an NA block
Chaotic_Warlord
Car: Black 5 speed Swapped 1995 240sx
I have a question for anyone who's upgraded their pistons to aftermarket ones. I am looking to turbo my block so I am planning to do a 9:1 piston swapout with the reinforced rods. My question is two parts; first is there any real performance difference between a stock 89mm 9:1 piston vs a 90mm 9: piston with a .050 overbore? The second part is if I do this would I see a decrease in performance over stock without having a turbo system installed or will I see an increase in performance. I'd do a search but honestly I have no clue as to how to go about searching for this specific question(s). I understand that upgrading to a 10.5:1 compression ratio would give me added NA performcance but since the stock ratio is what like 9.5-10:1 I don't know if I would actually degrade or increase my NA performance with 9:1 ratio, so let me know.
IPP has ross 9:1 pistons in stock 89mm trim are these good or should I fork out the money to do the .050 overbore? Any help you guys can provide would be beneficial and much appreciated.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Stock KA24DE ratio is 9.5:1 for all years...
And going to 9:1 will yeild very little difference...most accept 4% per compression point bump as a guide to HP increase. So if you drop half a compression point, you're looking at losing ~2% power...so ~3HP or so.
But you can make some of it back up by adding a little timing until you turbo it...it's all about cylinder pressure, and you can affect that with more timing.
- Brian
:: orion ::
Oh...and the diffference in displacement will be negligible...it's 3 cubic inches.
239Xcc versus 244Xcc...
Chaotic_Warlord
thanks you guys, I was looking at a smaller ratio but I can wait to do that until Im under boost. Plan on running stage 2 cams with reinforced valves and springs so the powerloss will probably not even come up. Wish my GI bill comes in so I can order the parts. Would I need to do anything with my ECU if I change my ratio, like would my fuel map change or anything.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
nah, you'll be cool and the gang, just keep saving up for turbo parts. you dont need to mess with any fueling if you're just losing a few compression points. i might advance my dist in an attempt to gain back a little top end, but this is entirely unnecessary
are you sure you wanna use the lower compression pistons while you are saving up for a turbo, or is this jsut going to be a thing where you only gotta save up for a few weeks
Chaotic_Warlord
My engine currently has almost 240K on it so all the parts and tired and beat up anyways. So since I am in need of doing a rebuild anyways minus well get the heavy internal engine stuff out of the way. I am joping to have my turbo kit by the spring so a couple of months shouldnt hurt, going to do this in stages. Just waiting on my GI Bill to kick in so I can go ahead and order the parts.
sunnys14
Car: S14
if you got 9:1 compression ratio with a .20 overbore, wouldnt the overbore compensate for the compression ratio loss?
SonyPete
Damn double posts
SonyPete
Yea increase in bore will bump up compression. But when aftermarket pistons state a certain compression such as 9:! they have already compensated for the bigger bore with changes to the compression hieght or changes in the dome or dish on the top of the piston.
