Question about Stillen sway bar install on 2011 G37 journey
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
CLTatenza
Car: 2011 G37 Journey Sedan
I received my sway bars in the mail yesterday and was expecting to receive at least new sway bar bushings, however from reading the install instructions it sounds like I am supposed to reuse the stock bushings? How will that work with the larger diameter bars? :gotme
Anyone with experience with these bars please let me know what you did.
Thanks!
CLTatenza
So from my determination to find an answer, it sounds like the Journey and sport both have the same size sway bars, and that the Stillen is actually the same size as well, just solid instead of hollow?
Can anyone confirm?
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
CLTatenza wrote:So from my determination to find an answer, it sounds like the Journey and sport both have the same size sway bars, and that the Stillen is actually the same size as well, just solid instead of hollow?
Can anyone confirm?
im sorry you have not gotten an answer yet. maybe check with infiniti to match part numbers for the journey and sport.
ddmander
Car: '11 G37xSport Sdn, Blk/Blk,
Stillen cat-back exh and Gen 3 CAI,
Kinetix cats, Motordyne M370 intake, Akebono big brake kit, 19" Bremmer whls w/Bridgestone R11s, lowered
The Stillen rear swaybar is solid and a larger diameter than the stock bar. Also, Stillen does not provide the bushings to fit and you can't use the stock units because they're too small. I wound up using Chevy truck bushings that were the right size. It works fine but I was a little disappointed in that Stillen did not provide all the parts needed to install.
audtatious
dd, thanks for the reply and welcome to NICO.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
wow that does surprise me as well.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
