rips187z »
https://forums.nicoclub.com/rips187z-u121899.html
Fri Dec 19, 2008 8:36 pm
water cooled or oil cooled? just want to run around 400whp on stock internals, will oil cooled be okay? or am i wasting my money? i picked up a used kit off ebay for 3000
Turbo Garrett 60-1/ (Turbo, Journal Bearing Garrett T3/60-1compressor (T04S housing) with 4" inlet and 2.5" outlet. StageIII Turbine wheel with T31 4 bolt exhaust housing. Oil Cooled Only - NOT Watercooled. Uses T3/4 oil feed flange and drain flange. Great 550 HP Turbo. Available A/R)
- TiAL 38mm External Wastegate (Silver Top)
- TiAL 50mm Blow-off Valve (Purple Top)
- Front Mount Intercooler
-Piping Downpipe
- Intercooler Piping
-Oil Pan Spacer
- Stainless Braided Oil Feed and Return Lines
- 550cc (Set of 6 direct fit) Injectors
- AEM Fuel Ignition Controller
is that worth th money, kits got about 3000miles on it or should i just send it back?
