4urxtc »
https://forums.nicoclub.com/4urxtc-u11536.html
Sun Nov 08, 2009 9:48 am
Hopefully someone will help me with a question I have about my S14 Sr20det swap, it is S14 black top. Well recently I replaced the oil pump and that was a pita because the motor was in the car. Anyway, I went thru everything even manually priming the pump. I used 10w30 Royal purple for new fluid all synthetic. I put an new nissan oil filter on the car. Well, upon starting the car for the first time I heard a rattle coming from the engine. Also, the oil light stays on in the dash. I have not revved the motor, nor have I let it get to temprature. So I investigated and noticed the sound was coming from the front cover above the oil pump. To me it sounds like the chain is rubbing or something. So I figured I need to go thru an get a new chain tentioner. Now does this sound like the proper thing to do? Or is there something else I should look at before replacing that? Previously to the install there was no such noise. I set the timing on the motor according to what I should. I set the crank pulley to the 2nd mark and the cam dimples to the grey chainlinks. Then I installed the CAS where the colored dimple lined up with the dent in the shaft of it when pushed into place. So, timing should be at stock.
So with this info please let me know if you have any suggestions.
I need to know about this oil sending unit also.
[IMG][/IMG]
I also have a Greddy Emanage Blue. Which is hooked to the ECU. I am guessing these are previously installed sensors but I really don't know which ones. So if someone could maybe help me figure it out I would appreciate it. [IMG][/IMG]
Modified by 4urxtc at 8:13 PM 11/8/2009
Modified by 4urxtc at 8:20 PM 11/8/2009
Modified by 4urxtc at 8:52 PM 11/9/2009
