Checkered-Member wrote:Can I ask why are you running such large injectors
cuz when u run teh nitrous and turboz you gotta have all kinds of fuel!
seriously though there's a guy selling RC DSM style 550cc injectors locally for 150$... might as well overcompensate now if you have grandiouse plans for the car in the future
here was my reply on the other site though:
Quote »after some research:
since the SAFC can only adjust injector duty cycle UP TO 50% +/- it would seem like the idle would be very rich if you could get the car started at all. it is possible to add an aftermarket FPR (like the Nismo) that replaces the stock FPR and reduce fuel pressure to compensate. I think the Nismo FPR is only a 1:1 rising rate FPR though. Anyhow if your not pushing the 550's to within an inch of their life and you have an adjustable FPR, I'd say it's do-able since you're going to have to push them more since you are at a lower level of fuel pressure, or add an 5:1 FMU in as well. but that kind of defeats the point and if you're getting a good deal on the injectors, you are negating that by spending more $$ on the FPR and FMU.
I'd say for what it's worth on your application (and mine for that matter) don't get bigger than 520cc injectors unless you are planning on buying those items right now anyway.
now someone else plz chime in and offer another opinion
(edit) here's where I got the 5:1 FMU from:
if your info is right and every 10psi in increase over base fuel pressure is like adding 25cc to your injector's capacity, the same would work in reverse. so you're dropping your base fuel to approx 32.5 psi. now as you increase your revs (we'll assume you're going to push 15psi) now you are raising your fuel pressure 5lbs to every 1 lb of boost. by 15psi your fuel pressure is increased to 107.5psi. still allowing you to use your injectors at mid-to-minimal duty cycle but not stressing your fuel lines/system past their limits (edit)[/quote]I didnt think about the ECU's ability to compensate too... hmm..
