Question about S15 SR20DET vacuum lines
redline808
Car: all
Hi,
I have the S15 SR20DET. Does any one know what the two vacuum ports located underneath the throttle body were originally used for? One of them has a one way check valve, but both lines are just hanging and I don’t know if they should go any where. I was going to use them for other vacuum uses, but I would like to find out what their intended uses was in the first place.
Thanks.
SpeedRacer1
Car: 1990 240SX, G35
Left one goes to a recirc valve or blow off valve. Right line with the one way valve goes to a solenoid valve for the charcoal canister, so you can probably toss that line.
