question about s14 sr20det's t28 turbo/comressor
Fenvy
Car: 2005 350Z Base 6MT
hey for those who has s14 sr20det notch top swap, or those who are familar with the subject
is the s14's t28 actually have a t28 turbine alone with a t28 comressor?
I always thought that the s14's t28 has a larger turbo compared to s13 sr20det black/red top's t25 which yield higher power...
but I was on heavy throttle's website and I found this
Quote »Turbo specs:Compressor: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Center Section: Ball Bearing[/quote]
so what is it suppose to be? a t28 turbine or just a t25 turbine except that it's ball bearing instead of journal bearing?
can someone clear that up for me? thanks!
Fenvy
wow no one knows?
