RalliartRsX »
https://forums.nicoclub.com/ralliartrsx-u39106.html
Thu Sep 21, 2006 3:15 pm
Well, as noted, I am looking into turbo lines from Taka (which I must say, has some of the best customer service, period)
Well, one of the problem is that one of the turbo coolant lines runs to the rear of the engine between itself and the firewall and its an extremely tight fit in there to change it around (albeit, the SRs seem to be as tight as a virgins ***** Sorry, just had to..............)
One of the options for teh SR boys was running a S14 upper water neck which comes from factory which a turbo coolant line bung fabricated in so instead of running the turbo coolant line behind the firewall, you are running it to the water neck infront of the engine.
My question is, does this thing bolt up to the CA18det without any modifications??
