Armstec_S13 »
https://forums.nicoclub.com/armstec-s13-u52419.html
Fri Jan 22, 2010 11:02 pm
Thanks for the post, I definitely understand what you mean about the paint under the gloss, since the car is 20 years old the color is brighter than originally painted in 89, that's what im worried about, the paint I bought awhile back was from the color code on my car, I was looking under the hood and saw the non metallic color, it seems to me to be some kind of enamel? That's why I called it a base coat, I figured I would use that color after the primer and then using the metallic paint last then gloss.
Cause from what my neighbor told me it would be good to use that color as a base instead of the primer, from what he said dark primer for dark colors and light primers for bright colors, something about the contrast,He used the example if I used a dark (black) with that gold that the final color would be a bit darker than if I used a light (gray) primer.
Who knows, im not gonna paint the front end, but I have to get all the materials for the paint.
*edit*To nap0le0n, the color code should be on the little metal plate inder the hood on the firewall on the passenger side, it has engine code, vin, color code and other stuff.
I am not exactly sure but I think the color code for the gold was "656" something like that, but I didn't know about the "base coat color code. Other than what ZX88 posted.
Modified by Armstec_S13 at 1:21 AM 1/23/2010
