AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Sat Oct 02, 2004 12:41 pm
A few things:
It's NOT a catalytic converter. The seller is a moron. It's a test pipe.
10-15 hp? Again, the seller is a moron. Hell, I've never tested a catback that would add 10-15 hp. His numbers are as bad as his "Engrish".
I believe OEM exhaust is 2.25".
Lastly, it says "chrome aluminum". If it is indeed aluminum, that's retarded, as aluminum does NOT make good exhaust components. It appears to me to be chromed mild steel, which means it will eventually rust.
It's also $65 AFTER shipping, which is not a smoking deal for a test pipe.
Hell, I can build you a flanged, bolt-in, high-flow catalytic converter, all emmissions-legal, for $155 shipped.
