if you plan to roll your fender up , then 245 is OK , but if not it will be rub special when you lower the car ..my tire is 245/35/19 with off set 30 and it rub the rear all the time until i rolled the fender up. good luckBlackmobile wrote:play around with a tire calculator, put in your stock tire size and try to find the right match, i think that 245/45/18 is about the same as stock. http://www.rimsntires.com/rt_specs.jsp? ... &text2=g35
Lol....wonder where I saw this before?white midori wrote:if you plan to roll your fender up , then 245 is OK , but if not it will be rub special when you lower the car ..my tire is 245/35/19 with off set 30 and it rub the rear all the time until i rolled the fender up. good luck
