Question about ride quality?
cali_m35
Car: 08 M35
I owned other Infiniti cars before my M35 and it seems that the ride quality on my m35 is harsher where my steering wheel shakes at times and it shakes when going over ruff spots on the road. Is this normal? I just got new rotors, tires, and just aligned the car.
Ilya
You might have issues with thing like sway bar links, bushings, etc. which is why you're feeling more rattle/roughness in the steering wheel. How many miles on your car?
StanR
Car: 2008
Infiniti M35 Luxury
Exterior: Black Obsidian
Interior: Rosewood, leather
I would agree with Ilya, I have a M35 and it rode smooth as butter until I put 20's on it 3 weeks ago. The 20's are coming off because of that reason, I loved the way the car rode and handled before the addition of the rims.
cali_m35
Car: 08 M35
I have 73k miles. Just purchased it last month.. How do I check the sway bar links and brushings? Much obliged.
Markc
Car: 2008 m35x
2005 infiniti G35
Check the front shocks/struts as well. I was experiencing similar symptoms in my new to me 08 m35x with 87k last fall. Noticed the left front shock/strut was leaking. Turns out it was blown. I replaced all 4 and the ride greatly improved. Not as buttery smooth as I thought the M would be, however.
I also own a 05 G35 sedan with sport package and the M was the replacement for a 02 I35. The M rides more like the G than the I.
Ilya
The M is not a boat like a Lexus ES/GS/LS...it's definitely more sporty. That being said, if you hear any kind 'clunking' while going over dips, etc. I'd bet the sway bar links are bad. I'm not sure of how to exactly test them...I'm the kind of car owner who will replace something at 80kmi just because it's a lot of miles, not because it's actually broken lol. I did a suspension refresh of links, bushings, etc. just cause and it certainly helped.
graffigna
Car: 2008 Infiniti M35X
My 08 M35X needs front struts and rear shocks. I cannot locate a source for the fronts. Where can I get them? thanks
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
Markc wrote:Check the front shocks/struts as well. I was experiencing similar symptoms in my new to me 08 m35x with 87k last fall. Noticed the left front shock/strut was leaking. Turns out it was blown. I replaced all 4 and the ride greatly improved. Not as buttery smooth as I thought the M would be, however.
Front struts for sure. Swaybar links are there for cornering stability and when bushings wear they clunk. Before I replaced my completely blown front struts, my steering wheel was all over the place going over even the lightest bumps in the road.
