flipintentions »
https://forums.nicoclub.com/flipintentions-u39762.html
Tue Apr 18, 2006 8:36 pm
I had a question I`m changing my clutch, clutch was slipping really bad it goes nowhere yada yada.... after 3 days finally got the whole transmission and motor seperated finally!
I know the flywheel is recommended that it should be resurfaced, I`m going to actuall get it done tomorrow but the flwheel is close to flat where the clutch disc contact surface meet is this normal?
or should it have more of an edge or lip layer what ever you call it i noticed discoloration and small cracks i guess from heat, i`ve taken clutch assembly apart never seen it like that before or based on the discription would you still be able to resurface?
if resurfacing is out of the question where can i get a oem one, money is tight so thats the only thing i can afford plus its a stock KA24DE 179k miles i`ve tried only one that has oem so far is autozone no one else has it.
I want to go ahead and replace the rear main seal also, after i attempted to take that one out the bolt on the bottom breaks where its bolted on the oil pan the rear main seal dosent leak yet i was shocked by that one, is this hard to replace any pointers.
