Question about replacing motor mounts
jtsarnak
I was wondering if anyone has ever replaced their motor mounts without actually removing the engine entirely. I need to replace my worn out mounts in my '95 SE w/ auto trans and am wondering what it involves. Please only reply if you've actually done this and haven't had to pull the entire engine from the transmission and out of the car.
MaxType 240
Car: 1995 S14
I've done it on my 5spd like that (2x):
Jack front of car, unbolt transmission mount, unbolt bottom/top of mounts, jack engine up (where transmission housing), ensure you are not stressing fuel/vucuum lines, switch, reverse the process.
Jesse
jtsarnak
Thanks for the feedback! I just have a couple questions:
So you actually jack up the front of the car, then jack up the engine/trans combo even higher?
And can you be a little more specific about where you are jacking the engine/trans combo from? I was going to lift it with a hoist, but with the car already jacked up it might be easier to jack from underneath.
Finally, about how long of a process is it?
Silvia007
Car: 93 Nissan 240SX SE Fastback
If you use a hoist, you risk the engine moving forward and stretching lots of vacuum lines and electrical wiring. With the jackup technique, you won't have that. He did say jack it up where the engine and transmission meets/bell housing.
Yes you jack the engine/transmission higher as the chasis is being supported by jacks.
As for time required, when I did mine by myself, it took approximately 2 hours depending on your mechanical skills.
MaxType 240
Car: 1995 S14
Additional notes:
I worked from the driver sideRemove the driver side wheel so you navigate easierTake your time jacking the engine up, frequently check the tension on vacuum/fuel lines just to be sure. My 5spd didn't have problems but I have replaced a lot of OEM lines w/braided hose...
Jesse
gumby
Car: '89 240sx sohc
so on average how long do mounts last? im reusing ones out of a 158k sohc that werent noticably torn. the other beater car has 143k sohc mounts that are torn. how much would it cost to have a pro replace em?
