question about reinstalling drivers window
93Z
Car: 1993 300zx 2+2
I took my window out to fix the regulator. now its time for the window to go back in but im having some trouble getting it back in. So my question is should i put the window in first then try to work the tracks in or the other way around. Its pretty tight trying to line everything up just right
Jevitto
Car: 1990 300zx N/A VG30DE 2+0
When I replaced my window/regulator I worked the tracks/guide first
Once you have that done you need to slide the window into the window clips located on the window regulator near the top
If the battery is hooked up you can raise or lower the window regulator as needed to make it easy.
Just remember to not leave the door open for too long because the battery could go out
