Question about RB25 Turbocharger
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
Can someone post all the specs of a stock RB25DET turbocharger i have been looking for the last 30minutes and i dont find much just a piece of info from AutoSpeed.and also what is the stock wastegate setting on this turbo?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
The stock 25 turbo is a T3 compressor side with a special exhaust side. It is not anything standard. I believe it was made by.. Hitachi? Ceramic exhaust wheel. Oil and Water cooled.
It's not bad for a stock turbo. It's not 'great' or anything, but put a 10lb (RB20) WG actuator on it and it works better than the factory 7lb.
I don't know if anyone has spent the time to compare the A/R or anything. I'm thinking not..
KlanjacOFF
Car: Nissan 240SX
It would be a great turbo if it didn't have a ceramic wheel and break so easily. Nitrous + Meth would make it soooo fun.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
240RB1
92 Nissan 300ZX Z32
Thanks to everyone for all the good info.
meet07
Car: 89 180sx rb25det
i put a manual boost controller on mine, turned it clockwise a few times to get 10lbs...
Sil240
Car: Nissan S13 "The One Cam Wonder"
Ricky I thought that it was a Garret unit.I read somewhere that in the late 80's-early 90's Nissan was working with Garrett/Air Research.Also the Turbine is larger than the Compressor or is that a typo?
Coolwhip
Vendor
to my knowledge T28 front, T3 rear, Hitachi correct.
240RB1
92 Nissan 300ZX Z32
I have a couple of more questions, the first is where could i find the banjo bolts with the lines for this turbo? i only have one banjo bolt but no lines could someone tell me how to make coolant lines for this turbo i went to 3hardware stores and an oreilys looking for fittings to fit this turbo but this is an odd turbo its different in every aspect even the oil line is crazy haha thanks for your time
