kouki-gymkhana »
https://forums.nicoclub.com/kouki-gymkhana-u9464.html
Wed Jun 08, 2005 11:09 am
Alright, since you have an s13 and plan on swapping in an RB25, you WILL have to indent the starter area on the firewall if you are using McKinney mounts or a modified R33 x-member. If you are using the stock R33 x-member I'm not sure but I tried to squeeze in my RB25 first using the R33 x-member (modified) and mounts and then with the KA x-member and McKinney mounts and neither would work without banging in the firewall a bit. I probably went a bit overboard in retrospect but I've got plenty of clearance now. The only cutting I did was for my FMIC piping but it was quite minimal. Even if you are planning on using the SMIC, you will have to cut a bit. You will also need a custom downpipe (~$150 at the local muffler shop.)
