Question about pistons
jojy
Car: nissan 200sx & toyota mr2
are the sr20de-sr20det stock pistons same or not?can i replace sr20det pistons with sr20de?
ray666
Car: '92 240 sr powered tuned with a neo
i would just buy what you know works, oem sr20det pistons.
http://www.thenismoshop.com/ik...d=268
takae86trueno
Car: 89 240sx coupe redtop sr20det
i just rebuilt my whole engine i didn't replace the pistons because they were practically new but the pistons are the same size in measurements but i think the compression ratio i believe are different. But i did buy the 91 sentra ser piston rings kit they work but make sure you buy the chrome moly piston rings that is the upgrade piston rings for turbo applications. And you can also buy the bearing kit its the same as the 91 sentra se-r if you have any more questions let me know i can probably let you know what are interchangeable because i just went through my entire motor and had things done right.
