TrunkMonkey »
https://forums.nicoclub.com/trunkmonkey-u454.html
Thu Feb 20, 2003 8:39 am
they probably are the sohc pistons, but there are several errors in his ad.
-you won't reach 200hp by just raising your compression.-the pump gas being used had better be 93 octane.-for every point of compression raised you get a 4-5% increase in hp.-the 11.6:1 compression is with stock bore only. if you bore 0.02" over the compression is 11.7:1 and 11.8:1 for 0.04" over.-you won't see a 32hp increase at the crank with a stock engine.
if someone spends $225 for those pistons, give me a call. i've got some sand from iraq that'll help keep your engine from detonating.
sohc pistons can be had for less than $35 each. just shop around.
-demetrius
