NightRyderNy wrote:Was curious about what the advantage to having oversized valves was? Was also curious about what would be have to be done to the engine in order to accomodate the oversized valves (machining process etc.) What are the pros and cons to the oversized valves and any other information. Thanx in advance.
more air. so you can run more fuel. bigger bang i'm sure you know the rest.
but then you need to calculate the port area to see if there is sufficient gains to be had from increasing valve size.
machining of the new valves, existing seats, and combustion chamber
in multi valve pent roof cylinder heads, there isnt alot of room. between the valves. some people manage to squeeze in 1 mm bigger valves.
