kouki_monstor »
https://forums.nicoclub.com/kouki-monstor-u33270.html
Fri Feb 17, 2006 11:13 pm
I just purchased a ka24de which Im about to swap in soon. But the problem is, the previous owner doesnt know what kind of engine oil was previously used in the engine. The engine has about 160xxx miles on it. Im planning on using 10w-40 for the summer and 5w-30 for the winter, Valvoline non-synthetic. My question is, would a simple engine flush be all that i need to safely switch to non-synthetic, assuming that there was synthetic previously used in the engine... just to be on the safe side? If it previously used non-synthetic then its out of the question... im just trying to be on the safe side here...Another thing, is it safe to switch from 10w-40 to 5w-30 in different seasons? As long as it's the same brand? Or is it the other way around? Diffferent brand but same weight and winter? Because if it's not safe to frequently change the oil weights then I'll just stick with 10w-40, since the engine has high mileage. Any suggestions would greatly help. Thanks!
