question about oil pressure gauge on rb20
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
ok so i know the rb lower harness has a wire for the oil pressure gauge that is stock on the r32 cluster. my question is can i take that wire and hook it up directly to my hpc oil pressure gauge? the hpc gauge has two wires so is one ground and the other the sgnal wire?
mello88
Car: s13
I was under the impression the stock Oil Pressure sender was basically an low-pressure on/off switch that just lit up the dummy light in the dash below a preset PSI. I may be wrong though.. I do know the port size is 1/8 BSPT though
BTW did your gauge come with a sender/sensor? And sorry for my moment of ignorance, what does HPC mean, is it a brand name or something...
driftmyke
they do have one for the dummy light but the second wire is for the oil pressure gauge in the r32 cluster.
hpc is a brand.
driftmyke
come on i know somebody knows
gawdzilla
Car: none
it might work but the reading will probably be useless (inaccurate). the sender needs to match the gauge
