guy looked up the drain plug and said the socket size was 12mm.. i guess ill see when i do the oil changempbclutch33 wrote:14mm on the drain plug. Use a 6 pt. instead of a 12pt. to avoid stripping it. Not sure about the torque specs. Tighten it by hand as much as you can and then give it about a 1/2 turn or so with a wrench. If you are unsure, take it somewhere.
you where RIGHT drain plug 14mm did it today. it was a pain at first but my first time ive ever done it myself so now it should get easier i hope. now to do one on the 07 trailblazermpbclutch33 wrote:14mm on the drain plug. Use a 6 pt. instead of a 12pt. to avoid stripping it. Not sure about the torque specs. Tighten it by hand as much as you can and then give it about a 1/2 turn or so with a wrench. If you are unsure, take it somewhere.
