smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Tue Feb 26, 2008 3:07 pm
If you're going with a new CD player, I'd say go for the new speakers while you're at it. Now to go with a new CD player, you need to upgrade your climate controls and the trim piece--that's going to run you about $300. Now, with that you can go with a new one that is double the size the standard size, called double din. That's the best way to do it. Otherwise you can get a standard sized CD player and find a kit to fill in the extra space as a compartment.
Speakers are probably sufficient for now, but a lot of aftermarket speakers will sound better than stock speakers. Sounds like you have the Bose, which tend to be lacking in bass, so I would recommend upgrading them as well. But you can do it later if you want to see what you think once you get the CD player in.
