Slipstream »
https://forums.nicoclub.com/slipstream-u31419.html
Sun Aug 19, 2007 6:07 am
Are you honing the cylinders to deglaze, or are you trying to remove enough material to go larger pistons? The fsm has the specs on what the cylinder walls diameter should be. You just have to make sure you don't oval or taper the cylinder. If you can afford it, it's easier to have it done at a machine shop.
