Question about my KADET What should i Do?
Spinn3r
Car: 1996 Nissan S14 Zenki T3/T4
To make it story short, I took the head out, and found out the head gasket was bad, oil was mixing with coolant, blue smoke on idle, yada yada, what happened head moved taking it to machine shop for inspection, still have to check on pistons/rings, Now question, Should i put ceramic head gasket? with ARP head studs? it is .5 bored over, with aftermarket rods, pistons, cams. OR should i stick with stock head gasket? and stock head studs? I just wanna run save 15psi of boost on pump gas. nothing crazy. Thanks
Spinn3r
ignore this: Decided to go with Cosworth head gasket and ARP head studs.
