Question about my brakes
steph_jay__
Car: M56X
I recently did an akebono upgrade to my 2011 Infiniti M56x. The problem I'm having now is that my brakes don't apply unless the pedal is pressed all the way down. The brakes were bled. I'm just trying to see if I missed any step, and advice would greatly appreciated thanks
Ilya
Did they come with new brake lines? Perhaps something is up with the lines and they can't give the necessary pressure to the bigger caliper?
steph_jay__
Car: M56X
Ilya wrote:Did they come with new brake lines? Perhaps something is up with the lines and they can't give the necessary pressure to the bigger caliper?
No they didn't, but I'm pretty the lines are the same between the sport and non sport package...
insanex1
Car: 2011 Infiniti M37 Malbec Black
R2C Intake
Kinetix HFC
Uprev
Eibach Springs
Tanabe strut bar
Akebono OEM
Paddle Shifters
I had a shop do mine and don't have your issue with stock break lines, do you have enough break fluid?
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
Not sure if you're aware, but the sport brakes have 2 bleeders per caliper.
beachbum718
Car: 2011 Infiniti M37 S
2 bleeders,did you use sport rotors?..if so re bleed and pump pedal till its hard then start car.
CRV_33
Car: 2011 Infiniti M56x
You should list all the parts you had replaced and installed on your car in regards to the Akebono brake upgrade. Seeing that you retained your stock brake lines, did you have the banjo bolts upgraded to the proper ones that are needed?
k67p67
Car: 2015 Infiniti Q70 Premium
2017 Nissan 370Z Nismo Tech
I suspect that there is still air in the system. Try rebleeding.
steph_jay__
Car: M56X
Thanks guys, there was some more air in there.....I rebled them and more air came out
steph_jay__
Car: M56X
CRV_33 wrote:You should list all the parts you had replaced and installed on your car in regards to the Akebono brake upgrade. Seeing that you retained your stock brake lines, did you have the banjo bolts upgraded to the proper ones that are needed?
Is there a special banjo bolt I should use?
