steph_jay__ »
https://forums.nicoclub.com/steph-jay-u256472.html
Wed Jan 13, 2016 8:01 pm
Ok so I recently upgraded to the akebono brake kit, the kit came with banjo bolts, however they were to short for the stock brake lines. I ended up using the banjo bolts from the stock calipers, the seemed to work but I was wrong. I'm getting a slight leak from the front lines. My question is, is there an in between banjo bolt I can use? Do I try and put a little thread lock on it? Do I (absolutely) need to replace the brake lines? Will Goku make it back in time to save earth? Find out next time on Dragon Ball Z....
Any info will be gravely appreciated
