smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Tue Nov 27, 2007 3:53 pm
I wouldn't really listen to the manual, just go with your instincts and watch the RPMs just as you were driving a manual because obviously different speeds and instances call for different gears. And to answer your other question, no you aren't actually shifting the gears, you're just telling the computer when you want it to shift.
When you switch over, are you at a cruising speed where you would be in 5th, or at a standstill? If you're at a standstill and its in 5th, you have a problem, but if you're cruising and it's already in 5th its not a problem.
