Question about MAF's (already tried search)
Rays_240
Car: 93 sr20det 240sx Hatchback
Alright I have a 93 hatch 240sx bone stock. I was dealing with power loss (bogging) on and off with the car. I decided to try cleaning the MAF. well while trying to clean it I broke it. The car idled wierd and didnt go past 2500 rpms. I drove the car home (about 20 min) like that. I then bought a used MAF out of a 93 altima with the same motor (ka24de). I installed it and my idle got worse and it stalls out at stop lights. however I now have my full rpm band back. The car is also running very rich blowing a ton of black smoke. Are the altimas and 240s interchangable? I then took apart my old MAF and put it back together soldering the parts the way they should have been. I installed it and it runs exactly the same as it does with altima MAF. do my MAFs work now and there is a new problem? the car ran great besides the random power losses before I messed with the MAF.
vancouverbc
Car: 1991 240sx
why not compare the serial numbers on the maf?
my 91 240sx is 22680 53f00 a36000 g60
vancouverbc
Car: 1991 240sx
search titles for altima maf
Okay, I finally found the answer to my question.Since the 2nd generation (98-01) USDM Altima's were equipped with the KA24DE engine block similar to the (95-96) 240sx S14, the MAF sensors are identical.
The 240sx/Altima MAFs compatibility also holds true for the 1st generation (93-97) Altima and the 91-94 240sx equipped with the KA24DE.
Just some thoughtful advice for those of you needing to replace your KA's MAFs
Rays_240
alright so if there compatible than what could my problem be? it ran fine until the MAF went bad. could I have damaged something while driving like that?
240sxbuffy
Car: 1989 240sx
dumb ? are all the hose and vacuum line back on? is the intake hose cracked?? how do you know the swapped MAF is any good?? the only way to check one is with an osliscope any unmetered air getting into engine after MAF will make car not run right
sharkerio_coupe
Car: 1991 Nissan 240sx Coupe Chuki Shark
1989 Nissan 240sx Coupe
1999 Nissan Maxima
1997 Nissan 240sx Kouki
1991 Nissan 240sc Hatch
1990 Infinit M30***
240sxbuffy wrote:dumb ? are all the hose and vacuum line back on? is the intake hose cracked?? how do you know the swapped MAF is any good?? the only way to check one is with an osliscope any unmetered air getting into engine after MAF will make car not run right
with an osliscope? if one is not owned, can you take it into an autozone or somethin n have them check it kinda like a battery?? i have the same problem with the MAF....after installing a known working MAF it stays the same...and all vacum lines and grounds are good....theres others with the same problem, havent found a solution hahai might have to take it in somewhere??? im dreading that some one will find something i missed and rape me
