Question about lowering.
artman540
Car: 1998 Nissan 240sx
I lowered my car to the point that when I turn, my tire rubs on the plastic trim inside the wheel well. I know I need to take the plastic out and relocate the harness at this point. My question is, if i take out this plastic, is the area behind going to rust? Is there anything I can do to keep debris from stock piling in my fender by my door?
AZ89two4Tsx
artman540 wrote:Is there anything I can do to keep debris from stock piling in my fender by my door?
Don't remove the plastic fender well.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Remove the fender liner.Cut the fender liner so that it will block debris from getting into the door area.Re-install the cut half.
No it won't rust, it's painted.
artman540
Excellent thanks for the quick reply.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Why not just undercoat the inner fender area after removing it if you're that worried about rust. It's a 90's japanese car it's going to eventually rust no matter what you do.
im_looking_for_a_240sx
+1 on the 1/2 cut fender liner. thats what i did. once you go low enough you may not be able to use em. then the undercoating would be best.
Philipio
Car: 96 240sx, 96 Miata
My fender still fills with crap even with the liner completely installed.
Chris28
Car: 92 s13 KA-T
Wait...there are such things as fender liners?
ILoveMyRHS13
Chris28 wrote:Wait...there are such things as fender liners?
Hmmm... No, I don't think so.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
they are silly. doesnt let you fit decent wheels.
junk em and forget it.
ZootedS13
Car: 1990 240sx se
mrgreeneyes wrote:they are silly. doesnt let you fit decent wheels.
thankyou
rip that crap out, tuck harness, drop it low low. prosper
that stupid plastic stuff promotes "honda rust" as they call it around here
bersh240
i like half fender liners.keeps the rocks out from dirt roads.
mrgreeneyes
Car: ///M5
bersh240 wrote:i like half fender liners.keeps the apples out from oranges roads.
you're silly.
you dont get rocks from a dirt road.
you get rocks from a rock road.
and dirt from a dirt road.
and your car should be LOW enough to cringe at the thought of "dirt roads"
silly bersh, you're silly
bersh240
a picture i took in maine.he has fender liners.
Dazzla
yeah my wheels rub the front of the liner at full lock...i might just cut it off the front peice
Philipio
My wheels rub at full lock too, not a big deal. I'd rather have them than not. My wiring harness is tucked too.
Chris28
Car: 92 s13 KA-T
My tires rub the frame at full lock. If that doesn't happen then you're doing it wrong.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
If you do remove the plastic liner you should undercoat the area. I sanded, primed, then used duplicolor roll on bedliner with a brush and coated the entire area. Cost about 25 bucks total.
