Eswift »
https://forums.nicoclub.com/eswift-u367.html
Tue Feb 25, 2003 2:56 pm
i tried a similar technique, and found that (at least on 94s and earlier) the outer layer is clear which is glued to an inner layer which is two pieces, one amber and one red. inside of that are the fresnel lenses. i doubt you can separate the colored layer from the outer layer because it is either permanently glued or thermoset together. You could, however, take the whole part off and put your own lexan layer over it, but i bet that would look like crap.
