First and most importantly, how do I remove the window and regulator assembly? It looks like I need to remove the window first, and then the regulator assy will come out by pulling four nuts, but I cannot get the damn window out! There are two stoppers on either side of the window with a bracket keeping them from coming out... so I turned those over so they are not keeping the window from coming out anymore. Then I noticed there is a little metal tab on each rail stopping the window from coming out, so I bent those out of the way. I also removed the outside door seal, because it looked like it might be in the way, but something is still stopping the window from rolling out... wtf am I missing? It's so hard to see down in there, so that doesn't help.
Also, less important but probably more of you know the answer to; Do I need this plastic in here for any reason? Or can I just pull it out and clean up the glue. The glue is disgusting, sticky, and has even dripped down off the door onto the doorsill...
