Question about injector upgrades
roplusbee
Car: 2007 350Z NISMO
Is anyone using 550cc injectors? And is it necessary to upgrade your fuel rail when going with bigger injectors? From what I have seen and read, it looks like the super sized injectors require fuel rail upgrades. I didn't think 550s were considered "large injectors".
Also, they should just drop in right (that is if they are new and I don't like the idea of used injectors). If not, an o-ring change may be the only change necessary, right? Thanks for putting up with me guys/girls. If this is a stupid question/post, feel free to blast away, but know that I am still searching even after I type this up.
Rob.
teddy
Car: Saab Turbo and MR2
So long as they're top feed, low impedance injectors, and you use the CA18 o-rings, they should fit. I've heard of some people saying their SARD injectors didn't fit, but I think they were using the o-rings that came with the injectors.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
What kind of power are you looking to make? Anything under 400 and the stock fuel rail should be fine. Anything more than 400, why the CA?
progman
I run 550s in my CA. Stock fuel rail. I used the o-rings that came with my injectors (they were CA specific). no leaks.
i don't know if you know this or not, but you have to tune your ECU for the larger injectors. I don't recommend using an SAFC to adjust something this dramatic.
roplusbee
Roger that. I didn't think that 550s would be drastic for a CA, bt live and learn Thanx guys.
themadscientist
That's what almost a 50% jump in size? I wouldn't trust an SAFC to tune that big of a change. I replaced the 260s in my CA18DE with 370s and I was setting my SAFC to -25% at 8000rpms and still getting downshift fireballs out the muffler.
progman
50% ???
32.73% goss
mazdaman
Car: 90 S13 CA hatch
themadscientist wrote:That's what almost a 50% jump in size? I wouldn't trust an SAFC to tune that big of a change. I replaced the 260s in my CA18DE with 370s and I was setting my SAFC to -25% at 8000rpms and still getting downshift fireballs out the muffler
themadscientist
progman wrote:50% ???
32.73% goss
I am definately math challenged but a 550 is 180cc bigger than a 370 180ccs is 48.65% of 370cc sooo it's almost 50% bigger. Now if I am wrong please put up the equasion and help me out. My math teacher hated me, I blame her
roplusbee
Wow. Fireballs, huh? I am having an ECu chipped and tuned for 550cc injectors, 20psi (rebuilt SR turbo) max boost (prolly won't see that for a good while), and Z32 MAFS. I am not prepared to do any tuning myself, because I do not have replacements for all of my internals (yet). I plan to rebuild, but not at this time (as I am away too much, gotta love rapid deployment).
I really don't have a HP/TQ goal at this time. I just want to add some more guts to my car. Maybe I will be able to set a goal after I experience what the car can do with "simple" bolt on upgrades. Then I can get into strengthening the internals and such to go big like some of the folks on the forum and surpass the magic number (for some reason, I have 300HP in my mind as the magic number).
I guess, it is safe to assume that I should be getting a clutch kit soon, huh? I just don't like the fact that I have read so many posts/articles where people are complaining about SPEC clutches. Are they warranted or are these guys trying to apply a "minimum" spec part to kinda cut a corner?
themadscientist
When I get my subs loaded in I am shooting for 300 on mine with the stock longblock. I can't say one way or the other about the Spec clutches I have a twin, it WORKS
ch187
Car: 90 CA 240sx
im using 450cc dsm injectors with ca o-rings. the stock fuel rail will be plenty big for any power goals. its already big...
roplusbee
Cool. FR-Sport only has Greddy top feeds listed at the moment, but I am kinda skeptical. I haven't heard anything about them. On the flip side, I haven't heard anything bad about Sard, but I haven't seen too many places to get them new. Guess I will just keep searching.
c-rad
Why not just get some Lucas/RC 550cc injectors for a DSM for like $210 brand new?
And as for the guy planning to run 20psi on his rebuilt SR T25, that's not going to happen. 14-15psi tops or you'll be rebuilding that turbo again in about 1k miles.
And for the mathematicians out there (or lake thereof) 1-(370/550)=0.32727272 ~ 33%. Either way, its too much for a SAFC.
SAFC should only be used for minute adjustments IMO regardless of what others say. Their car may run great, but its only because they are getting a lot of timing advance which is a ticking time bomb for a blown motor.
roplusbee
Right. I don't plan on running @ 20psi. I plan on running around 12psi by way of boost controller (electronic if I can afford it), I just wanted the max resolution on my ROM tune to be 20psi so that I have room for expansion once I get another turbo that can be handle high boost. Thanks for the concern though.
mikesim
c-rad wrote:Why not just get some Lucas/RC 550cc injectors for a DSM for like $210 brand new?
X2 about the S-AFC. you can't trust it to take out the timing, and with increased boost and fuel, you're looking at something that will never run as smooth as a ROM re-tune.
DALAZ_68
Car: 90' 240sx CA18det
sorry for reviving this from the dead...but question
i found some 550cc from deatchwerks...but they only have RB topfeeds...
now ive crossreference numbers with Tomei inj for CA and Rb and show the same part # for 550's...
when i asked Detchwerks, they said they only had high Impedance for KAe and RB...
but i thought RB and CA were interchangable...
can anyone shine some light on this?
beans33
Car: 1993 ca18det 240sx
I have a freind who is running my stock injectors in his rb20 +2. I run evo 560's and they fit just fine.
DALAZ_68
ill take that as a yes...its doable...ill take my chances since im down to the wire...
mbmbmb23
DALAZ_68 wrote:sorry for reviving this from the dead...but question
RB20, RB26, GTi-R, Eclipse/Evo/Talon, Rx-7 FC purple tops, are top feed low impedence, same as the CA. RB25/VG30/KA/SR/etc. are side feed.
float_6969
This is correct.
D_Stirls
Car: Nissan 180sx 1990 Ca18det
RB20 injectors well the ECCS ones (Not sure about the NICS versions) are high impedance, to use GTR injectors in them the have to wire in the GTR's dropping resistor as well.
EDIT!!
CA18de's are high impedance as well.
DALAZ_68
D_Stirls wrote:RB20 injectors well the ECCS ones (Not sure about the NICS versions) are high impedance, to use GTR injectors in them the have to wire in the GTR's dropping resistor as well.
EDIT!!
ok this just blew my plans out of the water...i need some 550cc Topfeeds for my engine dammit :tisk:
D_Stirls
EDIT!!
What were you planning to do, if you want to use high impedance injectors you just need to bypass the dropping resistor.
DALAZ_68
D_Stirls wrote: What were you planning to do, if you want to use high impedance injectors you just need to bypass the dropping resistor.
S15 T28
N60 Maf
KAe TB
FMIC
nismo FPR
Nistune
and from what im told 550cc would be what i need to not stress anything out,looking for only 230 , stay within safe limits, to keep the turbo and motor runnin as long as possible
how would you go by bypassing the resistor?
mbmbmb23
Just get some Evo 560cc top feed low impedence and call it a day.
http://cgi.ebay.com/ebaymotors/Mitsubis ... ccessories
DALAZ_68
i would, but wouldnt i need plugs? are Evo inj consistent?
DALAZ_68
i actually found these...
http://zilvia.net/f/sale-items/324525-f ... ctors.html
but i only need 4...lol :facepalm:
ser20det
Car: Silvia K's 88
DALAZ_68 wrote:i would, but wouldnt i need plugs? are Evo inj consistent?
I just Got my set of evo 560cc... Just get them cleaned and checked before u install them... I thing they need the proper ca18 o'ring
Those are suppose to be bolt on for the plug ... look the same as my 370cc
DALAZ_68
sweet...im waiting on word from my mech, he might have a lead on some...
so pretty much i dont need to worry about plugs, thats saves me some time and money... :biggrin:
