Question about injector and coil pack compatibility
95hondakillr
Car: 240s
I have parts from a 1990 VH laying around and was wondering if they could be used on any other engines. I have injectors, coil packs and ballast. Can the coil packs be used on any RB or SR engines? I was thinking the injectors and coil packs could. Thanks in advance.
BlackBirdVQ
Car: 93 G20, 94 Q45, 00 Altima, 01 Maxima- quite a few
injectors are same as a SR20DET- 370ccs (IHMO injectors are too big for the power VH pushes stock, but its nice to know that 500WHP on stock injectors is doable)
Power transistor can be used on a SR20DET - RWD.
CAS is very similar and probably could be used on a CA18DET.
I can't tell you if coil packs are similar to eighter one, as I always ran a distributor and wires on my SR20DETs.
