Simmsled »
https://forums.nicoclub.com/simmsled-u3103.html
Sat Feb 14, 2004 4:53 pm
Just a little info on I.B.
This type setup is best for mid-bass applications, ie. 8's or 10's that have been given a "band-pass" signal from the crossover. Do not get that confused with the "bandpass box". The band-pass signal from the crossover would cut out the highs with a lowpass filter at about 500hz and low bass from, lets say, a highpass 90hz filter. What makes it bandpass is that it has a band between high and low filters that is allowed to be played. This is easier on the driver's suspension and allows for greater power handling. Just remember that Infinite Baffle applications make it so that your driver has 1/2 power handling.
I would say that the biggest pain in the a$$ about this setup is the extreme amount of rear deck reinforcement that is required. With larger drivers or higher power, it is necessary sometimes to weld in sheetmetal and then dampen it. Otherwise, you should invest in a sound deadening material company because their stock will go up when you purchace the correct amount needed for your IB setup.
Kicker used to make Infinite Baffle 6x9s that kicked butt, but unfortunately they dont anymore.
Dont let this discourage you though as the I.B. setup, when done correctly, is very space efficient and can sound/look really good.
P.S. NY94J30, I love the OZ Opera wheels. Those are so choice. I would love to put a set of those on the Q45 we have in the family.
