mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Mon May 14, 2007 2:31 pm
I'm 99% sure they're o-rings (though from pictures online of other HLA's most don't have any... so I'm not sure)... I actually just encountered this problem yesterday myself. After some searching I found here on NICO someone making a post about rebuilding the VH. Basically the o-rings aren't available from Nissan, you have to replace the entire HLA. He instead got the proper measurement for the o-rings and got some Viton o-rings from a hydraulic shop (Viton would definitely be my recommendation, they're like silicone but handle oil much better and handle temps up to 400 degrees F). I've found many o-ring places to get them from... but have no idea what size the o-ring should be as the size was never posted in that thread.
I measured 15 mm for inside diameter of the o-ring hole and the total hla diameter is 17 mm. I didn't measure the thickness of the o-ring hole though, I need to do that to get a better estimate on the o-ring size.
