Question about headlight (HID), one side cannot work
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
jackie8z
Car: 2011 Infiniti EX35
2008 VW Touareg
Hi
I am fixing my wife's EX35 2011 headlight but get a strange problem. Really need your help.
The driver side HID light stops working for weeks. They are aftermarket HID kits 35W.
1. I checked the HID bulb, ballast, capacitor, and extension wire by switching to passenger side, they are all good = Issue is not HID kit.
2. Remove car battery and access the fuse box, both headlight fuses are good = No fuse issue.
3. Plug in original H9/11 bulb, the bulb works. = circuit is good, no need to check step 2.
My question is when HID is good, circuit and fuse are good, why I just cannot make driver side HID works...? Any suggestion?
Thank you!
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
after you plugged in the original bulb and it worked good, did you try to reinstall the HID bulb? Maybe there was just a back connection on the first try? Other than that, I would be stumped.
jackie8z
2008 VW Touareg
XIS wrote:
Wed May 30, 2018 9:13 am
Yes I plug back the HID kit but cannot make it work.
What I am assuming is the cable resistance become higher and thus electric current is not enough... I purchased the relay harness and will try again this weekend.
XIS
Ahhhh... yes - I didn't know you didn't have a harness. That should help with the HIDs (I have a harness with my HID)
All the LED headlights I have installed did not need a harness.
jackie8z
2008 VW Touareg
So just got it fixed with the relay harness.
I did not add relay harness in the past 4 years, everything was fine until recently. Time to upgrade to new QX50 I guess.
XIS
or a new QX30 :)
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
