Most dealers don't carry any gear oil (some do but most don't) because they use bulk oil from the hose reels in the back for service cars.yeldogt wrote:Just so everyone understands ..... The front and rear differentials use gear oil. The transmission and the electric transfer case use Nissan D matic transmission fluid.
The electric transfer case is fitted to cars with the "auto" dial on the dash.
The transmission and transfer case are drained and filled separately. I never screw around with fluids -- I use the proper D matic fluid. I bough a case online .. it's not expensive.
Many of the cars supplied with the electric transfer case also had the optional limited slip rear differential. You must make sure you use the proper oil in the rear.
M1 gear oil is suitable for LSD -- so it can be safely used in both the front and the rear differential regardless (LSD or not). Neither of my local dealers sell the Nissan gear oil -- The manual is a bit confusing. Years ago with a LSD -- one had to get an additive and add it along with the proper weight oil -- today with modern oil this is no longer needed.
Oh ok, I got ya. Surprisingly enough alot of automakers that ship their cars with LSD's from the factory DON'T supply the dealers with an LSD additive. I work for Toyota, and several models come with LSD's but we use Dodge additive in them, Dodge makes it. Go figure haha. Its all the same stuff though.yeldogt wrote:The card was pointing out just want you indicate. It was the additive part number that had me confused ... and the parts guy. It took a while to understand that it was simply an LSD additive ... and they did not stock it.
