Question about fitment
jms19delta
I am trying to figure out why I have the gap between the hood and headlights. Other cars with the kouki front end the hood sits flush on the lights. My car is a 95 with front end conversion. All parts are oem nissan except the hood which is VIS, so all good quality. Why is there such a huge gap??
jiffy08
Car: 92 hatchback 240sx
is that hood carbon fiber? if so, it might be those rubber stoppers that keep the oem hood flush. With the oem hood, i would think that because it is naturally heavy, it would compress those rubber pieces to a certain extent, creating the flushness. With carbon fiber, I would think that because its lighter, it doesn't exert the same force on those rubber pieces, thus not allowing them to compress as much. With that, the hood would sit higher. (I have no idea if this is correct, but it's just something I thought of.)
n_bushaw
Car: s14 Kouki Silvia , 04 Subaru WRX with hybrid swap
i think you just need to adjust the hood better. it looks like the hood doesnt line up with the fenders either. I took up the 3 or 4 hours adjusting mine. carbon fiber hoods aren't like OEM fitment. i have a seibon hood on mine.
AZ89two4Tsx
Just get a really fat person to sit on it.
MastaYu
Car: 92 Nissan 240SX SE HB
use zipties
Razi
Car: Moo
Check if your hood is hitting the rubber stoppers, if they aren't, then move your hood latch down a bit so the hood sits down lower.
moulton712
Car: coupe, hatch, both s13s
fyi, nissan has 10000 adjustments you can do on your car. do work son.
jms19delta
I'll try adjusting the hood tomorrow...thanks for the info!
SILVIAJayS
Car: 1996 Nissan 240SX SE
Also, the stock hood has a rubber weather seal that sits in that gap... it wouldn't fix your problem but it would help.
