Julio Bro! »
https://forums.nicoclub.com/julio-bro-u378.html
Sun Jan 12, 2003 8:35 pm
Alright, I lost some money experimenting and trying different setups and these are the truths.
Obviously more power means more flow, which means louder and more intrusive sound plus vibration.
More flow not necessarily means bigger or straight-thru exhaust, i'ts more a function of speed. You need to get a faster flow of the gasses coming out of the engine, too big an exhaust lowers speed, so careful about sizes. The choices: 1) You can maintain your stock tubing with a high-flow cat, no resonator and flow-thru muffler. 2) Bigger tubing on option 1 (cat-back systems). 3) Bigger tubing on option 1, but better flowing factory type muffler (IMCO, Walker).
I found out that what performance mufflers are designed to be very loud (particularly inside the cabin) and nice looking, but not much of a performance upgrade. Take a stock system and just change the muffler, you'll see gains are not great. I tried 4 different brands and type of mufflers. I tried an insert with NO muffler and that actually was quieter inside the car (outside was very loud) than any other muffler, because the tube alone isolates sound and vibration. Flow-thru mufflers are kind of sound chambers that produce very low frequency rumbles that get inside the cabin and hurts your hearing.
One of my trials was option 1 with the resonator. I measure the sound inside the car and the difference was like 7 decibels, which was like doing nothing, but low frequency vibration was more controlled. Power loss was evident, because the resonator internal tube is like 1.25", smaller than stock tubing and very restrictive.
I found out that option 3 is the quietest with power gains, probably 3 or 5 HP less than with a flow-thru muffler, but I keep my hearing OK.
Conclusion: Any flow-through muffler will be loud, even with resonator and stock cat installed; without them it's just louder. Bigger tubing brings up like 1-2 decibels with more vibration. Any factory type muffler with bigger tubing and hi-flo cat, will bring power up, without loud sound or vibration.
nnkfws333 if you keep the HKS the sound will not go away, installing another flo-thru muffler instead of the resonator is actually increasing the sound, because you added another sound chamber to the system. A straight tube is going to be quieter, to get lower sound, maybe that tube should be a .25" or .5" less than the rest of the system.
