Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Sun Oct 26, 2008 6:20 pm
It's not tuned for a specific boost level, it's tuned for a certain size injector and a certain maf. Timing is also changed a little bit. With increasing boost, it's up to what your maf and injectors can handle. If the tune is for 550cc injectors and a z32 maf, then the tune is going to be able all the boost it can until either the maf or injectors is maxed out, and at that point it's nothing with the tune, it's just the maf and injectors can't handle it. I think that's right, but hopefully an experienced tuner will come in to fill the gaps haha.
edit: SAFC and Emanage should not be used to tune the car, they should be used in conjunction with a rom tune. They are for slightly adjusting afr's so you can lean it out when cruising or w/e, but are not made to be the only thing used to tune your car.
P.S. I'll be running an EFI Specialists tune. On their site they have like 3 tunes, and they are classified by maf and injectors. On the one I'm getting, mild boost, they say it's suitable for the stock ka maf, 370cc injectors, and a small turbo such as a t25. That means any range of smaller turbos, some being capable of higher boost than others.
