This is in regards to my R50 2001 Qx4.
Does everyone follow the process provided by the FSM for draining and re-filling coolant/antifreeze?
My main concern is in regards to step 4 and 5, where it directs to open the drain plugs on the "right side" and water pump side of the engine.
If I release the water pump drain plug, does that mean coolant will drain from there? The FSM says "do not let coolant come in contact with drive belts", but the water pump side is directly above the belts.
Or perhaps, if I drain the radiator, there should be very little that drains out of the block and won't spurt out like I think it will, and is relatively safe from getting on the belts?
OR
Here's the section of the FSM that I'm referring to.
https://picasaweb.google.com/lh/photo/U ... directlink
Thanks in advance for any advice.
