goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Sat Mar 03, 2012 6:43 am
Matt- I haven't had trouble with the alarm on any of my Q's but the hood switch in the engine compartment has caused other owner's alarms to turn on randomly. Try replacing it with new, zip tying it in the closed position, or cutting the leads and splicing them together. Also look at the switch in each door that turns on the interior lights when the door is opened. Are the rubber covers intact and is the switch and mounting surfaces in the door jambs free of corrosion? They may not be grounding properly. I've got lots of door switches if you find a defective one.
