Question about compression test results?
mrk442
Car: 1993 240sx vert
Please Delete i am posting in the nissan mechanic forum.
So i was looking to buy an engine that is removed from the car. its a KA24DE
The plugs looked good and i ran a comp test using a starter and battery.
the results i got are below.. I realized after the fact that I forgot to open the throttle so i am sure they are low. How low will i read with a closed throttle?Also since the engine is cold i don't know how that effects the numbers?
#1 ~110#2 ~115#3 ~110#4 ~90
I added a touch of oil to the cylinders and retested
#1 ~140#2 ~143#3 ~140#4 ~120
The #4 cylinder is concerning me a bit but i don't know if its far enough down to be a problem? Plus since i had the throttle closed i don't know if these numbers can even be used at all?
what sort of numbers should i be looking for on a cold engine thats out of the car and been sitting for a month?
thanks for any help!
Modified by mrk442 at 5:48 PM 5/27/2008
