.http://www.racelandus.com/coilovers/nis ... overs.html
Front – 700 lbs/inch (12kg)
Rear – 400 lbs/inch (7kg)
Height Adjustability: Each shock body is threaded for infinite height adjustments between the coilover kits drop range. Integrated spring seats and locking perch are CNC machined and threaded to work with the threaded shock body to achieved desired ride height.
Locking Perch: The addition of the locking perch allows for the spring seat to maintain a locked position at all times when driving. The lower perch is spun securely against the spring seat to ensure that once height adjustments are made, they are maintained through normal driving use.
Tailored Fitment: These coilovers have been specifically designed to mount to and use the OEM strut locations, in order to allow a perfect fitment with no modification necessary. The OEM-matched fitment allows for the vehicle’s suspension to work as designed by the original manufacturer
