Question about clutch...thanks
HotCarl
Car: 1996 nissan 240sx (s13 blacktop sr20DET)
Hi I recently traded car for a 96 240 with a s13 blacktop sr swap. The prior owner gave me a new clutchmaster 6 puck disc with the car. I was curious if I can use my stock pressure plate with the disc. I'm on a budget at the moment so I'm trying to figure out the cheapest route to get the clutch in good shape. Any suggestions would be a big help.
Thanks
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Possibility: Yes.
I don't know how well the clutch will work with a stock pressure plate. As in, is if it is gonna be much of a noticeable difference or if you are better saving up for aftermarket pressure plate and just holding on to that 6 puck til you can get the new plate
HotCarl
Thanks for the response. Like you mentioned I'm going to try and hold out until I get back to work and can afford the proper setup. Luckily its not my DD.
codyace
Car: S14 w/redtop
HotCarl wrote:Thanks for the response. Like you mentioned I'm going to try and hold out until I get back to work and can afford the proper setup. Luckily its not my DD.
Thankfully. WAY to many make the mistake of trying to shoestring budget mod their dailys, and end up more often than not on the back of a rolloff truck haah.
TO answer your question it would work, but ultimatly not well. The pressure place would never be able to apply enough force to let the friction surface work as intended. It woudl work for daily driving and no abuse, but that's about it.
