question about cleaning the MAF sensor
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
I posted this by accident on the 240 forum somehow so I am reposting it here. I was changing the oil in my mom's 91' Q45 the other day and I removed the air cleaner assembly along with the plumbing to the throttle body to gain better access to the oil filter. As I took the plumbing off I looked inside to see what condition the MAF was in and I had seen a red colored oil coating the sensor which I am pretty sure came from the K&N air filter that the previous owner had installed. Now since I have drivin the car I have noticed that the car tends to stumble at times on the highway and I have to gun it to stop the studdering. I wonder if this is the cause. Anyway, can I use electrical contact cleaner to clean the sensor or will that ruin it? I read somewhere that you can but I want to know if someone here has done it with good results.Thanks,MattJacksonville, FL
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
I don't have an answer to your question, but I can tell you that the oil used to clean the K&N air filter is indeed red in color.
That is likely the cause. Folks have used electrical parts cleaner and non-chlorinated brake cleaner (sprayed carefully) to remove gunk from the MAF. In a worst-case scenario, the MAF will need to be replaced.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its undecided if the MAF failure rate can be compared to the K/N... One might think so at least..
Like JEsda said get some brake parts cleaner or electrical parts cleaner and spray it on there.....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Its undecided if the MAF failure rate can be compared to the K/N... One might think so at least.....
If you read the previous posts, I think you will find 80% of the MAF failures were using K&N, proabably the ohter 20% were running badly clogged filters.
Another way to look at it, only about 2 members who run K&N for over 20K have not had a MAF failure.
Then again, you could read the posts by Q45tech. He regrets ever having used one and never will again.
I am convinced.
One always accesses the oil filter from below on all VH engines.
qship96
Car: 1996 Infiniti Q45
I agree,the oiled filters contribute to the maf problems. at 161,000 miles,my maf has never been cleaned,and runs and idles as new.throttle body and butterfly cleaned once at 115,000 miles,and tech was surprised at how little dirt there was. on my old 300zx turbo i ran a k/n panel filter and had dirty throttle/maf issues.
CoastyAV8R
Car: 1994 Q45
Whats a good source for new one?
My car runs great when it's cold but as it heats up, it begins to hesitate and I"m leaning towards the MAF sensor. It ain't cheap, I'll tell ya that...
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
maxnix wrote:If you read the previous posts, I think you will find 80% of the MAF failures were using K&N, proabably the ohter 20% were running badly clogged filters.
I am convinced.
150K w/ a properly oiled K & N NO PRROBLEMS. The problem prob occurs when people over oil their filter.
mattd1979
Thanks for all the info. I'll get some contact cleaner and try that when I am off again. As for the oil filter, I take the aircleaner assembly out so that I can gain better access to it with the wrench to loosen it but I still have to take it out from the bottom. I feed it down as far as I can from the top and then reach underneath to take it out and vise-versa.
