ISUJinX »
https://forums.nicoclub.com/isujinx-u50362.html
Mon Nov 27, 2006 6:10 pm
Well... Dish pistons won't give you higher compression. The stock SOHC pistons are a very slight dish, i think 5cc's or so, in order to raise compression, you will need flat tops or domes. In order to get the right pistons without boring the engine, you will need to take measurements for the full length of the cylinder bore and size your new ones appropriately. So, which pistons you buy will be based on how much clearance you want, and how much your cylinder walls have been worn down. In any case, at least a good honing will help new piston rings seat properly, and is a good idea in any rebuild.
